I'm posting this plea for help on a few forums, including [H] and Reddit trying to find someone who can help me with a graphical/system error I'm having. I'm on the verge of skinning myself alive with how maddening this issue is, so ANY help would be appreciated.
Back story: I'm trying to run a dual monitor setup with mis-matching monitors. I have a Dell 19" and an HP LP3065 30" (Link). A friend couldnt use the 30in on his Mac -he thought the Mac didnt have DVI-D input/output- so he gave it to me. The 19 is analog, the 30 has 3x DVI-D inputs only.
I tried to use the 30in alone when my system was running an Nvidia 8600 (cheapo) GPU (Link). I plugged in the monitor, powered on and the splash screen and everything following was artifacted by green pixels/dots and both horizontal and vertical green lines. I assumed this was failure on the GPU's part as it was old, probably running down on its last leg and with nowhere near the memory to run such a monitor. I didn't think much of it except that I need a better GPU.
Since then I have upgraded my case (Antec 300) and PSU (Thermaltake 650) in a bid to prepare my PC for a new GPU.
For Christmas 2010 my friend gives me a 9800 GT reference design (Link) when he upgrades his PC. I replace my 8600 with this much more powerful card (ancient though it is/was) and I get the same artifacting with the 30" monitor. I thought theres no reason it should do it on this card, my friend ran his PC on his tv with it. I update everything with the new card and try to run the monitor alone. Same artifacting. The issue stops if I half the res to 1280x800, but of course I want the max resolution.
NOW, yesterday I recieved the Radeon HD 6950 (Link) I ordered, dropped it into the system, replaced the nvidia drivers with ATI, re-updated everything and plugged the 2 monitors in, fully expecting magic to happen. Of course, it didn't, and the monitor still artifacts at resolutions above 1280x800 and has weird junk happen to it if i pair it with the 19in. Switching the DVI-I ports the 30 in still gets artifacts, the 19 in isn't even detected.
I have updated every Nvidia driver, cpu driver, monitor driver, used UltraMon, literally everything I could think of to get this thing first to display 2560x1600 resolution and sedondly to add the 19in, to no avail. In fact, I've formatted my HDD 3-4 times now because when I change the res to 25/16 with Display Properties, it throws a run.dll error and forces restart, then blue screens after loading windows. It loops this. It also does this when I try to update mobo drivers. In Nvidia control and ATI CCC nothing is different; if I force it to 25x16 it just artifacts or turns off completely. If I try to run both monitors, it forces the 30in off again and borks the colors on my 19. This has been a nightmare trying to deal with this monitor, but it was free and I want it to work. So much junk has gone wrong I'm tearin out my hair here.
Points of interest:
- Mismatched 30 + 19 in monitors
- Artifacting on 30in when paired with 19.
- Artifacting on 30 alone unless below 1280x800 res.
- Drivers/CCC Up to date.
- HP LP3065 - 3x DVI-D input
- Radeon HD 6950 - 2x DVI-I, Display port, Mini-HDM output
TL;DR My 30in monitor is artifacting with a HD 6950 powering it, please help!
Points of interest:
