Z-Ro_da_Cr0oked
- Mar 19, 2004
Ok i plan on o/cing my ram, cpu, and vid card cause im about to hit the one year mark and would like better performance playin halflife2 and rometotalwar and such...
thats the front of my pc...
2 80mm collermaster fans...if i remove the front cover....i see that the metal kinda restricts the intake of air...(i also removed that fan filter)....so if i removed the metal would that be a good idea?
that is the side...
the fan on the window...was customed using a 80mm holesaw....i set the fan as an intake...
the cpu fan is pullin in air at the cpu...
or should i make it pulling air off?
that is the top of my pc...i customed that along with the window couple months back...
using a 80mm holesaw...right now its an exhaust...or should i set it to intake?
that is the back of my pc...
the psu fan is an exhaust and so is the back fan...
should i keep it like that or make it a intake?
and thats the vid card area...
i got a slowblower exhaust and 2 fans blowin air on the video card...
Thanks for answering my questions...
that is the side...
