ccityinstaller
- Feb 23, 2007
Hey guys,
USPS dropped off my 1GB 8800GT today, and I installed it in my box with the existing 8800GTS..I removed Nvidia drivers, and reinstalled 197.45 Drivers for Win 7 64....
Install was a breeze, Nvidia Control Panel shows both cards, with SLI disabled (I would think so considering this is a 890GFX board
)...I removed my existing GPU client, and reinstalled following this guide.
I started both GPU clients, configured them with Machine IDs 2 n 3 (MI 1 is my SMP Client)...Here is where it get's strange...Both clients show the hardware being used as my 8800GT, not the 8800GTS on the 2nd GPU client..GPU-Z shows my 8800GT loaded @ 98% and my GTS sitting idle...both log files show an argument of using GPU-0 and GPU-1, and that they have DL'd and are processing a WU...Here is the logfile of client 1..
Here is the 2nd Client's logfile...
Does that seem like everything is running normal?
HTML:
Launch directory: C:\Users\SLACKER\AppData\Roaming\Folding@home-gpu
Arguments: -gpu 0
[20:57:04] - Ask before connecting: No
[20:57:04] - User name: CCityinstaller (Team 33)
[20:57:04] - User ID: 59F9D13929956078
[20:57:04] - Machine ID: 2
[20:57:04]
[20:57:04] Loaded queue successfully.
[20:57:04] Initialization complete
[20:57:04]
[20:57:04] + Processing work unit
[20:57:04] Core required: FahCore_11.exe
[20:57:04] Core found.
[20:57:04] Working on queue slot 07 [June 5 20:57:04 UTC]
[20:57:04] + Working ...
[20:57:04]
[20:57:04] *------------------------------*
[20:57:04] Folding@Home GPU Core
[20:57:04] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:57:04]
[20:57:04] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:57:04] Build host: amoeba
[20:57:04] Board Type: Nvidia
[20:57:04] Core :
[20:57:04] Preparing to commence simulation
[20:57:04] - Looking at optimizations...
[20:57:04] - Files status OK
[20:57:04] - Expanded 73672 -> 383588 (decompressed 520.6 percent)
[20:57:04] Called DecompressByteArray: compressed_data_size=73672 data_size=383588, decompressed_data_size=383588 diff=0
[20:57:04] - Digital signature verified
[20:57:04]
[20:57:04] Project: 6606 (Run 5, Clone 276, Gen 66)
[20:57:04]
[20:57:04] Assembly optimizations on if available.
[20:57:04] Entering M.D.
[20:57:10] Will resume from checkpoint file
[20:57:10] Tpr hash work/wudata_07.tpr: 3045621167 2853982126 957399360 3059860971 1639493053
[20:57:10]
[20:57:10] Calling fah_main args: 14 usage=100
[20:57:10]
[20:57:10] Working on Protein
[20:57:12] Client config found, loading data.
[20:57:12] Resuming from checkpoint
[20:57:12] fcCheckPointResume: retreived and current tpr file hash:
[20:57:12] 0 3045621167 3045621167
[20:57:12] 1 2853982126 2853982126
[20:57:12] 2 957399360 957399360
[20:57:12] 3 3059860971 3059860971
[20:57:12] 4 1639493053 1639493053
[20:57:12] fcCheckPointResume: file hashes same.
[20:57:12] fcCheckPointResume: state restored.
[20:57:12] Verified work/wudata_07.log
[20:57:12] Verified work/wudata_07.edr
[20:57:12] Verified work/wudata_07.xtc
[20:57:12] Starting GUI Server
[20:58:53] Completed 1%
[21:00:23] Completed 2%
[21:01:56] Completed 3%
[21:03:29] Completed 4%
[21:05:00] Completed 5%
[21:06:30] Completed 6%
[21:08:00] Completed 7%
[21:09:30] Completed 8%
[21:11:00] Completed 9%
[21:12:31] Completed 10%
[21:14:02] Completed 11%
[21:15:31] Completed 12%
[21:17:01] Completed 13%
[21:18:31] Completed 14%
[21:20:00] Completed 15%
[21:21:30] Completed 16%
[21:22:59] Completed 17%
[21:24:28] Completed 18%
[21:25:57] Completed 19%
[21:27:26] Completed 20%
[21:28:55] Completed 21%
[21:30:24] Completed 22%
[21:31:55] Completed 23%
[21:33:26] Completed 24%
[21:34:56] Completed 25%
[21:36:25] Completed 26%
[21:37:55] Completed 27%
HTML:
Launch directory: C:\Users\SLACKER\AppData\Roaming\Folding@home-gpu2
Arguments: -gpu 1
[20:56:51] - Ask before connecting: No
[20:56:51] - User name: CCityinstaller (Team 33)
[20:56:51] - User ID: 59F9D13929956078
[20:56:51] - Machine ID: 3
[20:56:51]
[20:56:52] Loaded queue successfully.
[20:56:52] Initialization complete
[20:56:52]
[20:56:52] + Processing work unit
[20:56:52] Core required: FahCore_11.exe
[20:56:52] Core found.
[20:56:52] Working on queue slot 07 [June 5 20:56:52 UTC]
[20:56:52] + Working ...
[20:56:52]
[20:56:52] *------------------------------*
[20:56:52] Folding@Home GPU Core
[20:56:52] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[20:56:52]
[20:56:52] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:56:52] Build host: amoeba
[20:56:52] Board Type: Nvidia
[20:56:52] Core :
[20:56:52] Preparing to commence simulation
[20:56:52] - Looking at optimizations...
[20:56:52] - Files status OK
[20:56:52] - Expanded 73672 -> 383588 (decompressed 520.6 percent)
[20:56:52] Called DecompressByteArray: compressed_data_size=73672 data_size=383588, decompressed_data_size=383588 diff=0
[20:56:52] - Digital signature verified
[20:56:52]
[20:56:52] Project: 6606 (Run 5, Clone 276, Gen 66)
[20:56:52]
[20:56:52] Assembly optimizations on if available.
[20:56:52] Entering M.D.
[20:56:58] Will resume from checkpoint file
[20:56:58] Tpr hash work/wudata_07.tpr: 3045621167 2853982126 957399360 3059860971 1639493053
[20:56:58]
[20:56:58] Calling fah_main args: 14 usage=100
[20:56:58]
[20:56:58] Working on Protein
[20:57:00] Client config found, loading data.
[20:57:00] Resuming from checkpoint
[20:57:00] fcCheckPointResume: retreived and current tpr file hash:
[20:57:00] 0 3045621167 3045621167
[20:57:00] 1 2853982126 2853982126
[20:57:00] 2 957399360 957399360
[20:57:00] 3 3059860971 3059860971
[20:57:00] 4 1639493053 1639493053
[20:57:00] fcCheckPointResume: file hashes same.
[20:57:00] fcCheckPointResume: state restored.
[20:57:00] Verified work/wudata_07.log
[20:57:00] Verified work/wudata_07.edr
[20:57:00] Verified work/wudata_07.xtc
[20:57:00] Starting GUI Server
[20:59:04] Completed 1%
[21:01:08] Completed 2%
[21:03:12] Completed 3%
[21:05:16] Completed 4%
[21:07:20] Completed 5%
[21:09:24] Completed 6%
