Need help, about to pull the trigger!!
Ogre67
Buidling new comp...
3800 X2
7800 GT
Asus A8n Sli
2 Gigs of ram
Need case and power supply. No idea what to buy really whats overkill etc.
Any decent 450 - 550 Wat PSU will be good... Read the forums. Search google as i think there have been a few PSU reviews on some major Tech sites (Anandtech for example).
STAY CLEAR OF Q-TEC!!! Anything below £40 - £50 is really pushing it - no pointin spending £400+ on a decent setup only to power it by some £25-30 PSU...
Spend the money now and it'll save you days/weeks of headaches in the future... specially when you build a new PC and you get a fault...
As for the case - not sure, Coolermaster cases are nice, although it depends on what you really want. I'd go for atleas a case with 1 x 120mm outtake (or 2 x 80mm out takes - depends on if you want it to be quiet and perform well).
If you can, go either Antec, Coolermaster or Thermaltake - I've got an Akasa Eclipse 62 - awsome case, but it IS big, but i wanted it because of the 120mm fan mounts front and back (Helps with keeping it quiet :D) - plus it's got wheels... Have a look around and see which ones you like the look of.
neo out
Like English says, there's no reason to buy a crappy supply. The PSU forum here has a good sticky note about how to pick a decent supply.
For a case, isn't it really a matter of personal preference? Lots of folks think $200 for a case is overkill, but I really love the LianLi PC-V series. If you want to buy a cheaper case that you think looks nice, go do it.
Oh year, i forgot LianLi... some people swear by them, although they usually are more expensive than the "Average" case (if you can call cases these days average).
neo out
3800 X2
7800 GT
Asus A8n Sli
2 Gigs of ram
The only combos that I can recommend are the Antecs.
Either the SmartPower II 500W or the TruePower II 430W or 480W would be fine.
The SmartPower II 450W might be a little lite.
Ok, dont I need to be sure it has a special connector for PCI-Express? And ideally 2x of those since I do eventually plan to SLI.
Thanks
