Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
the line has little part of the desktop or game above it. so its not the vertical needing to be moved even tho its locked for some reason and i cant move it. also i cant move my mouse above it but i can drag the top of icons or go full screen in a picture and clearly see theres part of the pic or w/e.
just noticed that theres a line on the left side of the screen and my mouse goes of the screen on the right so it is out of place right? i try and move the screen vertical/horizonal but the options are locked. how do i unlock those options?
So wait - no matter what graphics card you use, the line is always there on your normal monitor - yet when you use a different monitor, the line is never there? Logical deduction suggests it's the monitor at fault - if you're using VGA it just hasn't been calibrated properly - expand the vertical size. If it's DVI, then the monitor's probably faulty - either that or the cable.
Yes but you haven't tried another PSU. I admit the PSU is the more likely chance, but I have had a 'no power' scenario be a different fault on several occasions before now. Does anything happen at all when the power button is pressed? (even if only very briefly) - if it doesn't, the PSU is more likely to be at fault, but the motherboard is not free from blame - ideally, you'd have another PSU to test (even if it meant removing some components so you didn't overload it - you can remove the graphics card entirely and see if the PC at least powers up at all on a different PSU, even though it won't boot)
When you say nothing - do you mean absolutely nothing? Does the standby rail power up? (e.g. do the USB ports become powered with the system still switched off)
Could be a dead rail on the PSU perhaps, might have gone bad and taken your PC's motherboard with it. Is there any intercompatibility with your brother's system and yours? If he's willing you could perhaps try using your graphics card, hard disks and so on in his board with his PSU (assuming it's powerful enough) to check everything else is AOK.
