PawNtheSandman
- Mar 13, 2003
I can't remember the site I saw it on, but I need the guide to do the led activity lightning window mod. Not that it is hard to do, but I would like to read the guide.
PawNtheSandman said:Ok
A guy took a window, dremeled the inside as lighting bolts. He then painted the grooved bolts with uv reactive paint. He hooked up his hard drive activity led to the edge of the plexi, so when he has hard drive activity, the window lights up and looks like a lightning storm.
well, i think THERES a guide right there with your description?PawNtheSandman said:Ok
wayne said:well, i think THERES a guide right there with your description?
should be pretty simple right?, use your modding imagination and creativity skills... jus cut the shape of lightening bolts then paint it with uv reactive paint, then wire a harddrive activity led to shine on the paint and voila, its done
didnt say i was gonna do it... i just said if it had to be done, it should be pretty self explanatory from his descriptionGrinder66 said:and post pics when your done.
