Need GPU recommendation
TeeJayHoward
Limpness Supreme
As you can see, a certain component simply will not fit. I need a recommendation for a new GPU. I can probably make about 240mm length fit inside the case. (I'll know exact numbers after I actually receive the case.) Anything over 3 slots would be a no-go. I'm coming from a 4080 and would like to lose as little gaming juice as possible, but I'm sure some loss is inevitable. Is there a stubby card that the SFF community uses regularly?
View attachment 783448 View attachment 783449 View attachment 783450 View attachment 783451 View attachment 783452 View attachment 783453
I saw this poor little abused and neglected beauty ( CMN B014ANF175 ) on eBay and couldn't help myself. I will be fully disassembling it, scanning each individual piece, reconstructing half of them in SolidWorks, then getting bored of the project and shoving it in a closet to sit for a decade or two.
Some possibly unrelated items also got purchased from Amazon:
View attachment 783456 View attachment 783455 View attachment 783454
Time to brush up on an old dusty/rusty skillset: Parametric modelling of organic shapes. NURBS, here I come!
Verify the slot format and generation for us, please. I guess it could be PCIe, but I am suspicious. Haven't looked up the date of production.
240mm or so basically means a 2 fan card. 5070 maybe? You can get those with 2 fans and under 240mm long. Alternatively, you can also get RX 9060XTs and 5060Tis in that size. 16GB versions will have more vram than a 5070 but won't be as fast. I'm not aware of any RX 9070s or RTX 5070Tis with 2 fans.
edit: Sapphire Pulse RX 9070 has 2 fans, but they're spread out a bit and the card is still 280mm long.
Inno3D had a 2 fan 5070 ti at 250mm long. But its been discontinued.
That wireframe looks like an old sgi o2 case, rad if that is what you are building!
I didn't realize that the 5000 series cards could get that small. just looking at AMDs 7000 series cards and non go shorter than 260 and that was a generation ago.
How big is the vertical space you can work with in the O2 case? Could you have the GPU fans oriented out the back of the case and route the pcie lanes via a flexible riser cable? That may buy you a slightly longer card envelope.
IIRC, it's basically a wash - same dimensions vertical or horizontal.
