I am one of the moderators for my universities local LAN club and I go to 5-15 LAN's a year as well as hauling my PC back and forth between friends houses on a regular basis. I want to find a case that will stand up to the constant movement better than my LANcool K-58W. The plastic parts keep getting knocked out of place when I move it and I also need more than four hard drive bays. All the cases I see have 5 5.25" drive bays and only 4 or 5 HDD bays. I am looking for something similar to a NZXT Phantom 410. (a friend of mine loves hers) I loved all the features that the Lancool had but it is not sturdy enough and lacks the HDD space. If possible I would like a smaller case but if not I am OK with the current size. Around 20 lbs or less would be good too, same as the LANcool and the NZXT. ( I am strong but lazy
My budget is $150. I would like to keep it around $100 if possible though.
I have an ATX mobo so no micro cases please.
My Video card is a gtx 670 windforce, 10.5 inches long.
Any suggestions + reasoning would be helpful.
Thanks
Thanks
