Need glide wrapper that works on GTX260
zzz
I've tried Sven's, dgVoodoo, eVoodoo, and xgl200, with no luck for Diablo 2 (WinXP, GTX260, 185.85). Sven's is the only one that even boots the game, and then it's mostly black with some crazy artifacts. Sven's used to work great on my 8800GTS.
Make a shortcut to Diablo II. Then right click on it go to compatibility tab and check disable desktop composition. I was having this problem too and had tried many glide wrappers, but this worked for me.
Thanks, that really made my day! It turns out that "Disable desktop composition" is a Vista-only option, but I was able to fix the problem by changing the compatibility mode to "Windows 98 / Windows Me".
Diablo 2 is so much better in Glide mode that it's a shame most people run D3D. Glide framerate performance is better, and D3D seriously blurs all ground textures.
