need front USB w/mobo header
mckeonm
I'm looking for a cheap beige 3.5" front USB panel for my case. Preferably four USB 2.0. I want only panels that use motherboard header, no internal USB connectors. Can anyone help?
Check these guys out. You should be able to get just the inserts with the usb connectors, then mod them wherever you want them on your case. :)
