- Mar 8, 2007
I have a Silverstone TJ07 and if you are framiliar with this case then you know that it was two 120mm fans below in the hard drive chamber, two at the top exhausting, and two 80mm intakes blowing right over the CPU.
The problem is no side vent for the video card. I want to get some fresh cool air over the videocard.
I have plenty of open front drive bays. My question is, what is the best solution to put a fan in the front drive bay. Silverstone has a drive bay converter with an LCD fan, but is it suitable for just a front intake if I don't intend to use it as a drive bay?
Also, does anyone have any experience with the Scythe Kama bay? Are there alternatives to the Kama Bay?
