I use a dual analog controller that came with my XFX 7800GTX vidcard ..and it is a bit sensitive , but I got used to it ..and you can adjust steering in control options to dumb it down a bit if you cant get used to it..
..if you controller is a wee bit on the worn out side tho ..then your *$%@!!..
