Anyone know where I could get large sheets of the black washable foam that comes with the 3 piece foam filters?
Need to make a 6 fan custom dust filter.
I can't halp you with that but if you won't find any you could use panty hose instead. It works great and should be easily available in number of colours
I don't know about foam but home depot sells black air conditioning filters that come in flat sheets for pretty cheap. They work well too. They're black brillo like material I use it in my cases it gets all the dust pretty effectively.
Interesting!?!?
Was just there, picked up this black plastic lattice-lick air filter support frame that can be custom sized by cutting it. It came with a thick blue air filter and this think black charcoal mesh air filter. Going test it out and see how restricted it is.
Interesting!?!?
Was just there, picked up this black plastic lattice-like air filter support frame that can be custom sized by cutting it. It came with a thick blue air filter and this thin black charcoal mesh air filter. Going test it out and see how restricted it is.
A friend of mine uses dryer sheets.
Dryer sheets are pretty restrictive. I can't see them as being airflow friendly.
