whisper
- Mar 16, 2003
Sorry if this is a lame question. But I am looking for a PCI firewire controller that has internal headers for connection to the front panel port of my newly purchased Lian Li case. I really don't even care about rear external ports. I have found several controllers that appear to have 3-4 standard external ports and one internal port, but none with headers that would accept the 9 individual pin connectors (including ground) that comprise the IEEE 1394 I/O cable of my case. Anyone seen anything that might fit the bill?
Edit: Just to clarify, there is nothing special about the I/O cable of the Lian Li case... it is the same as any case that has a front firewire port. Usually you connect it to the headers on your mobo, but since I'm upgrading to a mobo that doesn't have them I need a PCI controller that does. Thanks again.
