Harlequin76
- Sep 22, 2011
Hello,
I am building a Ft03 case, and I am almost done in what I want.
According to the Form:
1 more thing, I don't want AMD GPU.
Here is the build:
Case: FT03
PSU: Seasonic X660 modular
Motherboard: Asus Maximus IV Gene-Z
GPU: Asus GTX 570 Dcuii
CPU: Intel i5 2500k
CPU Cooler: Corsair H80
Memory: Corsair Vengeance 1600mhz cl9 8gb (the red one with heat spreaders)
SSD: OCZ 120gb vertex 3
HDD: Samsung f3 1TB 7200rpm
Fans: Akasa Apache 120mm x4 (2 instead of the silverstone angled fans, and 2 instead of the corsair stock).
Monitor: Dell Ultrasharp u2311h 23"
Mouse,Keyboard,Pad,Extras: I am going for mostly roccat, I think(keyboard not sure)
The computer fits my budget, I don't want Extreme power ,but rather good power and good temps, and low noise(as much as possible at least. I am planning to OC my CPU ( any ideas how far I should go? or I just test it slowly and go up till satisfied?)
Anyway, any thoughts?( I am already super close to buying these items,already reserved them in the store)
Thanks!
Harlequin76
Since we're getting a lot of questions recently about building SFF systems, I figured I'd adapt the General Hardware sticky thread for the SFF arena. Please cut and paste the below questions and your answers into any new thread asking for design and building advice, part lists, etc...
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Overclocking, Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
Gaming,Photoshop,web browsing and so on.
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
no shipping, I bring by myself I reduce the tax since I don't in that country.
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
No brick and mortar store worth mentioning that is cheap...so I am buying abroad (flying to the UK next week)
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
Mentioned below
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
No
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
No Crossfire/SLI, the board I took has usb 3 and 6gb/s so I am happy with that.
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?1080p
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
under the table
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I prefer not.
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Very Important, the best I can (need to be quiet at least in Idle)
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
No
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I don't have, What to buy? windows 7 64bit (but home,pro , or ulti?)
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
1 more week from now
By answering these questions you help us help you build a PC that's of better quality, better performing, cheaper or all of the above. The more details the better responses you will get.
Here is the build:
Case: FT03
CPU: Intel i5 2500k
Thanks!
Harlequin76
