Need Feedback on my Hardware Choices
Finneal
All,
I've got my Christmas system picked out now, thanks to all of your help and wanted your opinions on my choices. I'm on a budget and don't really plan to mess around with overclocking much unless I can get away with doing it with stock air.
I already have a BFG 7800 GT video card, a Lian Li aluminum medium tower case, and a Dell 20.1" flatscreen.
Here we go:
DVD/CD RW - Lite-On Black DVD Burner
HDD - Seagate Barracuda 7200 RPM 250GB SATA150
Mobo - EPoX EP-9NPA+Ultra ATX AMD Motherboard
Sound - Creative SB Audigy 2 Value (OEM)
PSU - Antec TPII-550
Memory - 2 x 1GB Crucial DDR 400 (OEM)
Processor - AMD Opteron 170
Some of the questions I had were whether the Opteron was worth the extra 80 bucks or so over the X2 3800+? Also is it bad to go with OEM memory, HDD, Sound card, and DVD ROM? Also, would all of this hardware work well toegther or am I going to run into connector/driver problems?
Any assistance you guys could offer would be greatly appreciated!!
Thanks again,
Charles III
You can definitely get away with overclocking on stock cooling. I have actually seen good overclocks from the Opterons using stock cooling.
For the DVD burner, I would loom at the NEC 3540A. I do not know enough about either to know which is better, but the NEC is the most recommended for a reason.
Is there any reason you chose the Seagate in particular? It is definitely not a bad choice, but I would go with the Western Digital Caviar WD2500KS. It is a great performer, has a 16MB buffer, and, IIRC, is not any more expensive then the Seagate.
The motherboard and RAM are perfect choices, exactly what I would've recommended.
You could always use onboard sound if you don't really have speakers to take advantage of that sound card. Either way the sound card you picked is fine.
Change the PSU. That particular PSU is known to have ventilation problems. I would get something like a Seasonic S12-500.
You could try to find an Opteron 165 and save a bit of money. Both will overclock the same. Also, yes the Opterons are worth it. They overclock better and have more cache. You can also buy the 165 for cheaper then the X2 3800+, IIRC.
Thanks Kooldrew.
As for the Seagate, I picked it because it has a 5 yr. warranty and I think the WDs only have a 1 year. Correct me if I'm wrong. Also is the buffer bigger on the WD? If so, what difference does that make?
As for the speakers, I have Klipsch 2.1s. They are great speakers, but are they good enough to take advantage of the better sound card. Tell me if you know because I don't =p
I will take a look at the DVD burner you recommended. The guy that responded to my first post suggested either Lite On or NEC, so I'm sure he would agree with your recommendation.
Anyone else have an opinion on the PSU? I only picked it because I saw it reommended numerous times on these forums. Also read quite a bit of reviews on Newegg and lots of folks had good results with it. I will also lookinto the PSU you recommended tho.
I will also keep an eye out for the Opteron 165 you mentioned.
Thanks again for your input. It is very much appreciated.
Charles III
