|CMF|SoulAssassin
- Mar 3, 2008
Hey Guys I've encounter a little problem, My router seems to be working fine when I'm not messing around with it, For instance when i try to open up some ports, (port forwarding) Then that's when all hell breaks, What I'm trying to do is open VNC ports so i could log in my computer via remotely from a difference location for example work. I'm able to access the router and even change WEP passwords look at attached devices view mac addresses do everything except for Port Forwarding, When i hit that button i get disconnected from The Internet, and it says page un able to view weird eh ?I have to do a hard reset in order to get service back up. Other then that its seems to be working fine with my wireless connection and Wired Connection
I have One Computer physically connected to it and 2 Laptops and one Desktop on Wireless Connection
I don't know maybe update firmware or update Versions ? but yet one i search for Update version build in the router it says You have Current Update
model Number is - WGT624
Thanks in Advanced
Thanks in Advanced
