Need Dual Display Help
I am thinking about buying a samsung 17 inch lcd at officemax and currently have a sony 15 inch lcd. I have a geforce mx 440 and I check the nvidia website and it says it supports dual display monitors, but when I look at the back it has one dvi and one vga. Do you think this will still work. Also, will I need to update any drivers or anything.
it will work fine, you either have to use vga on one monitor and dvi on the other, or purchase a vga to dvi adaptor to use vga on both.
