need driver for motherboard
r4d4r
Ok please help me.....
in CPU-Z it says i have a seanix MS-6526......but the northbridge cooler has a MSI logo on it.....
anyway, last week i reformated and re installed win xp, but i dont have the original mobo drivers, and i cant get my onboard lan working, i tried all the drivers i could find, even ones from MSI, and i can not find it....
what my question is, is if i look on the motherboard, what do integrated network chips look like?
You should call them. They will almost always give you the direction for the driver. You might try to google it, but that is almost always, worthless(500000000000000 hits and none of them work). Drivers for proprietary stuff is a pock shot in the dark with blinders on. That is why they suck.
You have an OEM MSI 6526 board, try running AIDA32 and get the chipset off the board..then you can find the appropriate drivers assuming this board is working in your system...
http://www.baber.com/baber/411/msi_6526gl.htm
http://www.msicomputer.com/product/p_spec.asp?model=MS-6526GL_L
Have you verified that the onboard LAN is not disabled in the bios?
Try reseting the bios then see if the LAN works, also try a different LAN cable...you never know it may just be the cable that is busted...it happens sometimes.
Later
MD
You can find drivers for the ms-6526 on MSI's website. I had to do it for a computer I was working on at the office today. In fact, that's how I found this board.
