Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm wanting to build a small lan case. Looking for dimensions for ATX & micro-ATX motherboard "backplane" for custom water-jet/laser-cut. Anyone have a dimensions or CADD file (.dwg or .dfx)?
Thanks. Formfactors has some info, but I was looking for someone that had already done the math, particularly, agp/pci openings (and distance from i/o opening), power supply opening, etc.
Well, unless someone chimes in, you'll need a caliper to take measurements from an existing case. A good caliper should be in every modders toolbox anyway.
