Need cooling for OC'd DS3/E6400/PC-V600
ococ
NewB here..but I feel I've done alot of research already.
Cliffnotes: I can do 3.0ghz, 1.318v, 12hr Orthos stable, but Coretemp reads 67 loaded. What's the best fan/heatsink I can fit on a DS3 board in a PC-V600 case. I think my clearance is ~80mm tall before hitting the PSU.
Long version:
DS3, E6400, Patriot Extreme PC2 6400, Stock cooling, PC-V600 case, AS5
Here's what I'm able to do stably, using Orthos, temps are measured Core temp under peak load:
3.2ghz, 1.41(auto), 72 deg!
3ghz, 1.318, 67 deg
2.8ghz, 1.318, 64 deg
Stock- 2.16, 1.325, 54 deg
I feel like I can easily do 3.2 or even 3.4 with some better cooling. I'd like to get a fat Scythe Ninja, or Zalman 9500 but limited by the PSU clearance. Also considering the Zalman 7700 but not sure if it fits the board since the NB heatsink is right next to the CPU and the memory slot is not far off. Any other HSF/HS options? Any other suggestions on tuning/tweaking?
Thanks!
I am thinking of going with the DS3 and PC-V600 as well. Are you sure about the 80mm clearance? Also, what PSU are you using?
I was hoping to use the Thermalright XP-120, which is 63mm without a fan, plus 25mm for a fan maing it 88mm.
The PC-V600 is 210mm wide. XP-120 plus fan is 88mm and Seasonic M12 PSU is 86mm so thats 174mm by my calculations without taking into account the height of the motherboard and CPU.
If that doesn't work, I guess I'd be going Zalman 7700 too but it doesn't review as well as the XP-120 with regard to noise and cooling.
Im using the scythe infinity cooler, but cant say for sure that it will fit your case. If it was me, I would change the case cause the scythe infinity will cool your CPU down greatly if the heatsink wont fit.
Thermaltake Big Typhoon with a giant 120mm Panaflo should bring down the temps quite a bit.
Ran a A64 @ 1.5v with 37C load.
That won't fit into the case w/o moving the PSU though.
Why dont you just buy another case? Im not trying to be a smartass here, I just dont understand why people do these things. Dont build your computer around your case, buy a case built around your computer ;) If a case was my limiting factor in stopping me from using a great heatsink, I would find a better case to "work" with what I have.
I dunno about the other guy but for me, I bought the case, then realized that I wanted to OC beyond the stock cooling. Also, I wanted something that was quiet and compact. The V600 was the best I could find short of going to a SFF. As you can see, i can still get a ninja in there with some minor modifications :D
I think that is gonna be your best bet. Heck, even trying to fit a waterblock in that case is a tight fit. :eek:
Yes, I watercooled my V600. Specs in sig. ;)
