Need Cooling Advice
zetachi
I have an EPOX 9NDA3J MOBO and just ordered an Opteron 144 CPU. Now I need some suggestions on a CPU cooler. I've heard and read much and am norrowed down to the Big Typhoon (not sure if it will fit my MOBO) Xp-90 XP 120 or an Arctic Cooling Freezer 64.
Anyone have any experience with this mobbo and any of these?
All opinions wanted/welcome.
Thanks
Nothing but good things on the XP. I have a Zalman 7700 and it's nice. I also like the fact I can use it on a 775. Either one i believe is good. I dunno about the XP but I know the Zalman blows air all around it.
the xp90 and the artic freezer 64 would fit with ease but i would not recommend using the artic freezer 64 on that mobo due to the socket's orientation which would face the fan blowing upwards while you would want it blowing towards the rear exhaust fan instead, the xp120 would fit the motherboard but would block the first ram slot and the big typhoon i think should be fine esp. since it is a tower cooler but be sure to measure your case since this heatsink is about 15cm tall
all are great coolers but heres how i would rate them based on how they cool
big typhoon > xp120 > xp90 > artic freezer 64
If you plan on overclocking, stay away from the freezer64. It does an admiral job at stock speeds though and is damn near silent. Another hsf that I've had great success with is the Scythe Ninja. Even when I ran it with only 1 120mm fan it keep my cpu around 40c load @ 2.8ghz.
oh yeea one more thing....remember to post pics of it in the thread in my sig :p i wanna see sum good shots! :D
