Need cooler master hyper 212 Plus Fan help
4LC4PON3
DERP!
I bought a hyper 212 plus and installed the heatsink and fan. im not sure if the fan is ran on bearings or not but its making an odd noise. its very faint but when your sitting next to your pc you can hear it.
What are some 120mm Quiet fans you recommend. Price is NO object. I want this thing silent and cool
grab yourself two gentle typhoons and put 'em in a push/pull
the end
mine's running with two slipstream pwms
i was just a bit too cheap to spring for the gt's
i have heard the gentle typhoons are awesome. im going to grab of them and replce all my 120mm fans as well.
i ordered the typhoons. got them from jab-tech newegg was out of stock. thanks
