Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am hoping to get an aluminum case for under $100 that works well with watercooling. Can some of you suggest some. I'm also mounting a radiator on the back of the case just like swiftech uses on their kits. I'd rather not go into modifying the case.
Here is a picture of mine before I redid the loop and the rad.
And here is after:
This picture doesn't show it but I moved the pump closer to the back and on an angle so I was able to shorten the tubing from the GPU to the pump. I don't have any pics showing the moved pump but it fits fine.
i second the masstige. I loved it when i was watercooling. Downgrading my computer now so I don't watercool no more. Fits a dual 120 rad up front w/no mods needed and has room for a larger pump like the ehiem in there as well. Just makes for an easy build and a clean look. Not to mention its only a mid-tower so it doesn't take up a lot of room.
