Need Cable help
Need some help guys. I have one LCD that I want to have my PC and Xbox 360 hooked up to by DVI. Also, I would like to be able to use the same speakers for both machines. I was wondering what kind of cable or switch I would need to have both hooked up and not have to swap cables for video and audio all the time. Thanks.
There may be cheaper solutions, but when I was faced with this problem I bought a receiver.
It will take all of your inputs and put it to whatever monitor/tv you have, plus it serves as a higher quality sound system that you can hook better speakers up to.
I have a 360, PS3, and my PC all hooked up to a HK AVR... works beautifully.
