Need Build Help on New Office Computer
Klade
Hello,
I am trying to build a new office computer. Its nothing too fancy since all it needs to do is word processing, email, and quickbooks. I have a build ready but I want to make sure its going to work alright. This computer will be using XP to start with and may upgrade to Vista sometime down the road. My main concern with this build is whether my motherboard will support a Dual Core chip since it does not explicitly say so.
Case: http://www.newegg.com/product/product.asp?item=N82E16811190057 Athenatech A100BB.270 Black Steel Desktop / Mini Tower Convertible Case Computer Case 270W Power Supply
Motherboard: http://www.newegg.com/product/product.asp?item=N82E16813130060 MSI 945GM3-F LGA 775 Intel 945G Micro ATX Intel Motherboard
CPU: http://www.newegg.com/product/product.asp?item=N82E16819116037 Intel Dual-Core E2140 Allendale 1.6GHz 1MB L2 Cache LGA 775 Processor
RAM: http://www.newegg.com/product/product.asp?item=N82E16820146526 http://www.newegg.com/product/product.asp?item=N82E16820146526
Card Reader: http://www.newegg.com/product/product.asp?item=N82E16820300901 (do they make a decent one of these, all the ones I've seen on newegg look like crap) LINKSKEY LKA-CR15B 19-in-1 USB 2.0 Black Card Reader/Writer
HD: http://www.newegg.com/product/product.asp?item=N82E16822148262 Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
Monitor: http://www.newegg.com/product/product.asp?item=N82E16824009100 Acer AL1917WAbd Black 19" 5ms DVI Widescreen LCD Monitor 300 cd/m2 700:1 Built in Speakers
DVD: http://www.newegg.com/product/product.asp?item=N82E16827136120 LG Electronics DVD Burner SATA
Thanks in advance for any help.
Please list parts along with those links. It makes it easier for people to help you instead of having to click on a dozen or so links. Thanks.
The Pentium E line of CPUs are actually castrated Core 2 Duos. The only problem I can forsee is the need for a newer BIOS in order to detect the "new" CPU.
I would strongly suggest picking up a better quality PSU, since most bundled ones are very low quality, and can damage other parts (eg mobo/cpu/ram/vidcard/drives/etc). Unfortunately, its hard to find a good quality mATX PSU and newegg doesnt carry the seasonic versions. Does the case/psu have to be mATX?
The RAM you chose was on sale at frys.com for $35 per 1GB stick, but they may be out of stock now. Actually, for the price of those crucials, this A-Data kit would be a better choice: http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
Another question: why not buy a dell? They have good deals every so often. The last good deal I saw was an E4300, 1GB of ram, 80GB HDD, CDRW/DVDRom combo, 19" monitor, and XP Home for <$400.
The PSU shown on newegg is a sparkle which is a good name brand (assuming it comes with that one) so I'm not worried there. Thats actually one of the main reasons I'm going with that particular case.
Ya, it looks like frys is sold out of the RAM, oh well. 82$ dollars isn't that bad.
As for why not buy a dell.. cause there is no good deal going on right now. If there was, your right I would buy one if I could get a decent one with a new monitor for less then about $520 which is about what this one will cost including shipping. As it turns out I already have an extra HD floating around.
However even I can't find a dell deal in recent history that gives me 2 gigs of ram, and a new monitor for less then 520 shipped.
You don't need 2GB of ram for word processing, email, and quickbooks.
If he's planning on upgrading to vista he might need more than 1gig of ram, I'd also get a cheap pci-e card for vista down the road.
I'm posting on a 19" widescreen monitor, the font gets a little small at 2ft of distance if you wanted to know.
Sadly I really do need 2 gigs of ram for XP and absolutely for vista. The people using this computer do not have enough know how to keep it in good condition. It will quickly fill up with crap after I turn it over so the 2gigs is basically my insurance policy to make sure things don't slow down too much too quickly.
It is a concern however that the fonts look small. What is the resolution you keep your monitor at?
If text size is an issue, you can set the system to use a larger font size. Or, you could consider a 19" standard instead of widescreen.
Yes, 2GB is ideal. You mentioned the reason you didnt want a dell was because they only had 1GB. Well, an additional 1GB stick would only be $35. So, adding 1GB to the dell deal I mentioned earlier would have only bumped the cost to $425 ($390 + $35) for an E4300, 80GB, 128MB vidcard, 19" LCD, 2GB ram, combo drive, and XP home. Similar deals are available from time to time.
However, you seem dead set on building it, so as I said earlier, the only concern would be the board not recognizing the chip due to an older BIOS being shipped with the board. With that said, you may want to consider a G33 Express chipset based board instead.
I actually have that case and PSU you listed, and the 270W lasted a couple years. Sparkle is ok for low end systems, but some of their PSUs are just too cheap.
Thanks for the response. My concern over the font size is that the people using it really have weak eyes and always complain when I turn their other monitors to their native resolution. I think I might buy the non-widescreen equivalent.
If you dont have a server doing backups for that workstation, I would consider getting 2 hard drives and doing RAID.
