Need Best 2D quality PCI-E card
polemos4u
Hi,
My wife works from home doing payroll/general computing. I cobbled a system together for her out of the garbage (literally) that is working great. Anyhow upgrade time is upon us and I built a decent system but am stuck on the video card. The current on hand card is a 7600gt from nvidia. The 2D quality is not up to snuff ... my wife speaking.
I put my 1950xt in for the time being to appease but I need a long term solution.
Sub $100 range
PCI-E
DVI out
Best 2D available
Thanks in advance
ya most ati cards imo have a crisper picture then nvidia cards. also you dont need to spend that much if your not gaming.
I wasn't aware there was much picture quality difference for 2D between cards. But if she likes your x1950 Pro, maybe a x1300 will suffice?
http://www.newegg.com/Product/Product.asp?Item=N82E16814121551
She didnt really like the 1950 she just noticed the improved image quaility over the 7600gt. I had that nvidia card in another system and figured it would suffice...
Well basically it went like this.
"I hate new computers."
"This looks worse then the old one."
Mind you we have 4 kids and she works part time from home so anything I do to ease the process helps keep the peace =)
thanks for the replys I will look into the 1300
I don't know what their PCIe lineup is like but look at Matrox. They've long been known for top shelf 2D cards, and probably the only reason they are still around given their weak 3D offerings.
However please note: With DVI I really doubt you see ANY 2D quality difference. The difference in a 2D image normally comes form the RAMDACs, those are the digital to analogue converters. As with a CD player or sound card, better DACs = better picture. Well DVI is all digital, so there really isn't likely to be a difference.
As far as I can tell at work ATi and nVidia cards are the same pixel for pixel on the desktop over DVI.
