need basic wireless keyboard/mouse for cheap
Max-Powers
tired of the stupid wires... whats a good wireless keyboard/mouse? for like 50 or $60. play games, windows 2k, wont be to far from my comp when using it. curently use a logitech mx 300 and a really old old keyboard. i hate keyboards w/ the button between the ctrl and alt. unless I can disable it, i dont want it. dont want a big keyboard...
opticle mouse a must of course
i have this.. and haven't had any problems..
http://www.newegg.com/app/ViewProductDesc.asp?description=23-109-130&depa=0
there are a lot of logitech ones for about $35.. there are some cheap ones too.. you can go to your local B+M store and see what feels good to you, then order it online too..
and the windows key is very helpful.. "window + E" opens explorer, "window + D" minimizes everything to the desktop, "windows + L" locks the computer, "Windows + R" opens the run dialogue...
there are more, but those are the ones i use....
you can always pop it out..
(i was fixing a guy's comptuer at work, and the X key was gone.. so i took the "home" key and put it there, because seriously.. who uses the home key??)
