Need Advise
ta7mike
New to the board, and have been away from the "Self-Build" scene for a while. I really need to upgrade my PC which is an Athlon XP 1400+ on an MSI K7T 266 PRO-R, have about 756 RAM, it has a decent video card, NVIDIA GeForce4 Ti 4200, but when i benched myself on 3DMARK03 it came out to a poor 1245. I really like playing RTS games, like Warcraft, but when i tried playing Warhammer Dawn of War, i really saw my dilemma. can anyone advise, for what's the good upgrade plan for short and long term. thinking of getting the BFG 6800 OC now, and upgrade in the new year to an AMD 64 with the MSI NEo2 Plat. mobo. is this the right strategy....??
You would see a bigger performance boost by upgrading the CPU and motherboard first, and upgrading the video card later. 6800 will be bottlenecked by your CPUs slow speed. The performance on an A64 with your current 4200ti would probably be acceptable to you and would be a significant speed boost in games as well.
Thanks! Exactly the quality reply i was looking for. Do you know if I can use my current RAM for that MSI Neo2 Board. I guess the board and a CPU of AMD64 3200+ suffices.
You should be able to if its DDR memory. "Should" because sometimes the A64s/motherboards can be picky about RAM.
IGNORE: Stupid question: How do I find out other than opening up my case if i am using DDR memory?
I checked and its one 256 and one 512 PC 2100 DDR. That should be fine right?
