Hi guys.
Well, I recently got an Onkyo TX-SR606 receiver, and love it. The problem is that it runs extremely hot. The manufacturer says this is normal, but I'm not ok when my room suddenly turns into an oven, which makes me uncomfortable. Yeah, is that hot. So I want to cool it, for as cheap as possible (~$50 +/-).
My plan is to place two fans either inside the case, or on top of the receiver. Inside would be ideal, but I need to check if there is any sticker that voids the warranty. I already did the measurements, and I can fit up to 2 fan as big as 140x140x32mm. However, I prefer 120x120x25mm fans because there's more selection, higher efficiency for cheaper, and I can re-use them in the future for something else. To solve the problem of creating a loop of hot air, making the problem worse, I tho' of adding a duct in the exhaust end so the hot air wouldn't get combined with the cool air. Here's an illustration:
So far I want to just get Fan1+Fan3, even tho' someone in my family suggest I do Fan1+Fan2 configuration instead. My problem with that idea, is that I fear hot air is going to get stuck in the corner of the duct, and just create pressure there, and that's why I think Fan1+Fan3 layout is better.
Another possibility is to do a Fan1+Fan2+Fan3 configuration, where Fan2+Fan3 CFM is equal to Fan1. For example, 2x50CFM fans + 1x100CFM fan. This idea sounds great, but I'm not sure how practical it is, and is it worth all the extra money to get the extra fan? And what is your input about the previous ideas I stated?
This are the items I plan to use, for either Fan1+Fan2 or Fan1+Fan3 setups, but I also want suggestions here:
1x Plastic Fan Adapter 80mm to 120mm
1x Evercool 80mm Fan Duct
2x Scythe "SLIP STREAM" 120mm 1900 rpm Quiet Case Fan
1x SilenX Ixtrema Pro Series 4 Channel AC/DC Fan Speed Controller
_______________________________________________________________________
Total: $76.94 ($66.79 + $10.15 shipping)
So yeah, this is well beyond my budget, but I still need to check other places for prices, and consider the ideas you guys are going to give me. Also, I can perhaps run the fans from my computer, since I have a 4 channel fan controller, and 2 of them are free, but I'm having a hard time finding extension cables long enough.
Ok guys, thanks for reading, and hopefully I hear good ideas on how I can do this the cheapest ,efficient and quiet too.
