Need Advice!!!
Riktar
OK guys its that time for me to upgrade the case. Let me began with the problems i currently have, I am currently using an Antec 902 my board is a Asus Rampage Extreme II....
It barely fits all my satas are jammed in there due to tight space. So i need something roomy.
Next problem i have cats and live in a trailer, so dust and hair are my enemies and i clean my case every 1-2 weeks. Yes the 902 has front filters but not on top where i have a huge 200mm fan sitting. Aside from the 200mm i don't mind cleaning my filters, wish they were a tad easier to get to though.
Next problem I do use Asus 560's in sli temps are good at 60c most heavy games (i.e. BF3) but if I increased airflow I'm sure i could get temps down. My 920 Bloomfield has a Thermaltake Frio sitting on it and temps get at 55c so once again airflow/headroom.
Next thing i should cover is i want to spend no more then 200$. I am currently looking at this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811163185
However i see no posts about filters, which worries me a great deal. So I am here to ask if you know a case that would fix my problems plz link it (preferably through newegg) and explain why you like it.
Thanks again
-Riktar
I think the raven lines are a really good idea for you. I have both the 2 and the 3 here, and I must say, I will never use another case type other than these. My primary system has been running for 14 months now and still not a single piece of dust in the system at all, and we have three cats, a dog and a snake. I am using the raven 02, as it has much more room than the raven 3. I used the raven 3 on my son's rig and it is awesome too, but a little bit smaller. The only problem I had with my raven 02 was its sheer size and where to put the damn thing, and its also what I call a left handed case as opposed to the raven 02 which is a normal oriented case. There are filters in both, and the way the case works with the pressurization is frankly fucking awesome here...
