I currently have a dilemma? Should i choose plan A: Upgrade, or Plan B: replace. My current config is. A64,939 3500 @ 2.4GHz, 1GB DDR, NF-3 M/B , 6800GT AGP 256MB.
I will mainly use this computer for playing games at 1680 x 1050 resolution.
Plan A: Wait for next technology cycle. (Vista, DX-10 GPU...maybe K8-L)
Cheap mobo w/ moderate O/C functions. (voltage,v-core,ram,core)
X1800XT,7900GT or X1900GT
Plan B: New computer with the following
Intel E6600 (will most likely O/C)
2GB-DDR2 RAM
ASUS/Gigabyte 975 or 965 board.
X1900XT or RV580+ or 7900GTX class board?
What do you people suggest?
Also, just want to ask.
How much performance advantage will a Core 2 make over a A64 @ 2.4GHz at 1680 x 1050 resolution? (aren't most games really GPU limited? (BF2,GRAW....) ?
Will a very fast Intel conroe give me a "significant" difference in framerate compared with a athlon 64 @ 2.4GHz assuming i only game at 1680 x 1050 resolution?
2GB-DDR2 RAM
