Need advice, troubleshooting - compability issues! Thanks
That really isn't enough to help us....
Please list out your entire rig -- as specific as possible -- and include which specific Pentium 4 processor you have.
Do any fans spin?
Do any LEDs light up?
Did you try re-seating the CPU?
Is the CPU compatible with that board?
Is that RAM compatible with that board?
Did you try a bare minimum config, outside of the case?
Did you try other spare parts, to figure out if all the parts work?
What else have you tried?
Do any fans spin?
two red LED's light up on the mobo, supposedly normal according to the manual.
CPU is compatible
RAM, IDK if it is unbuffered or not, it seems to be compatible according to specs.
I tried running just the CPU and the VID card and it doesn't work. No beeps, nothing.
I tried taking it out and putting it back together completely, reseating the CPU, nothing works :(
thanks
Which case do you have? Do you have any stray motherboard headers and/or loose screws that are behind the motherboard?
