Need advice/recs on new system.
DocBoc
Well I had a bad BIOS flash nightmare and my system is kaput.
Looking to go Barebones from Monarch with the following Config
Case: 100159 - No PS - Antec Performance One P160 ATX
Power Supply: 101246 - PS 750W - Thermaltake Toughpower W0117RU
Motherboard: 110829 - Asus M2N32-SLI Deluxe nForce 590 SLI Audi
Processor: 120983 - AMD Athlon 64 X2 3800+ Dual-Core 512K Per
Heatsink Fan: 130845 - Thermaltake CL-P0075 K450
Thermal Grease: 800018 - Shin-Etsu G765 Thermal Grease (Cools CPU
Memory: 141822 - DDR2 (533) 4200 - 2 GB (2 pcs 1GB) Buffalo
I have a brand new Plextor 755a DVD drive
Quick question on my current hard drives, will I be able to plug them in without having to reinstall windows(at least until i can back some stuff up and do a clean install?)
I am trying to keep this as inexpensive as possible, but at the same time, want to make sure I am leaving myself with a decent upgrade path/lifespan.
Any input would be helpful.
thanks.
ok, I think I can get away with that. Might just say screw it and do a clean install first as penance for fouling up the BIOS flash and recovery.
thanks for the linkage.
I am going to go with PC Power & Cooling 510 for the power supply.
I am switching to JNCS.com and barebonesing it. I am reluctant to seat the processor and heatsink myself and they offer a 3 year warranty including tech support, a little more money than Monarch, but after factoring in the warranty and tech support, the gap closed significantly.
I spoke to them as well about the memory selections and they were very forthright about an impending change in memory due to the finicky nature of the Mobo.
I have a decent case already, but would need to upgrade my vid card, memory, power supply etc. so I figured it would just be better off saving me the time and aggravation of trying to assemble it myself. I am still going to be installing the hard drives and dvd drives.
i also think I am going to stick with a 939 board and save a little jingle as there is more than likely a new socket coming out for AMD next year, so why bother with the new socket and I can save some coin with the memory I already have.
Thanks for the responses so far.
