Need Advice on Watercooling
JJU357
I have absolutely no idea on what would be good in terms of parts for a watercooling setup. I have an A64 3200+ winchester on a K8N Neo2 Plat. with 1GB of corsair pc4400 low latency TCCD ram. This is in a thermaltake tsunami dream case. I need some recommendations for a good watercooling setup including cooling the GPU which is a x800XT AIW. I have no parts currently so I would appriciate it if you could tell me what kind of tubing and fluid i will need too. Thanks for all the help.
Is the asetek waterchill unit any good? I'm reconsidering this and thinking maybe just a CPU loop is what I want. I may want to upgrade my GPU soon anyways...so let's say a decent water cooling set up for just the CPU and a budget of around 300.
how much more would it cost to cool my gpu too? just out of curiosity. i take it i would need a dual fan radiator and a block for the gpu....if its only going to be another 50 or 60 bucks i think i might just go that route...any more suggestions top nurse as to which gpu block would be good for the x800xt aiw i know the aqua computer ones seems nices...but is the 90 dollars worth it, or can i find one thats sinilar for less. just kinda pricing it out now to see. thanks again for all the help
the fact that you have an AIW card makes things a bit more difficult.
the dangerden maze 4 GPU works pretty well and is reasonably priced, but does not fit on "most" AIW cards, according to DD.
what about the waterchill unit asetek has for 349.99. It will cool the CPU,GPU and NB and has a triple radiator with a 320 GPH pump. Is this a bad option?
