need advice on these cards please!
INFRNL
Ok, just looking for an emergency backup card. prices listed are after rebate and google through buy.com. They have either 6200 $4, 7300le $10, or 8400gs $25. I am thinking either the 7300le or 8400gs. which would be the better deal? I cant find any comparisons between the 8400gs and the gforce 7 series. I think the 8400gs is close to a 7300gt.
any input would be greatly appreciated. thanks in advance
Honestly, if its just a backup card and you won't be doing any kind of gaming / video editing or heavy usage, just get the cheapest or whichever has the lowest MIR or the better CS (eg: BFG / XFX / EVGA if they are offered).
The 8400gs is the best out of that bunch, but its also 2.5x - 5x more expensive than the others. The 8 series does offer the best image quality and video abilities though.
is the 8400gs equivelant to the 7300GT or slightly better? may also get one for my dad. he doesnt game, just kids games maybe, and he watches tv through a tuner card, and possibly some movies. may get the 7300le for emergency card since its only $10 after rebate, save me $15, or could get the 6200 for $ and save another $6. will have to comepare specs, I dont want any of that turbo cache crap or whatever its called.
what should I be looking at exactly to see which one is better? cause you cant go off clock speeds anymore. are the pipelines, & shaders the most important?
Yeah.
These are the biggies:
Memory Bandwidth: 6.4 GB/sec
Shader Operations: 14400 Operations/sec
Pixel Fill Rate: 3600 MPixels/sec
Texture Fill Rate: 3600 MTexels/sec
All of which the 8400gs did better in. However they are still very low for any kind of gaming with higher settings or large resolutions.
