Need advice on purchasing a budget card
jblank
I currently have a PNY Geforce FX 5600XT (the underclocked one)256MB AGP 8X card. I would like to upgrade but I am way out of the loop on what is better than what I have, but in the pricerange I am looking in.
Here is what I have found on New Egg that I think is better than what I have:
http://www.newegg.com/Product/Produc...82E16814133153
http://www.newegg.com/Product/Produc...82E16814133106
http://www.newegg.com/Product/Produc...82E16814125141
http://www.newegg.com/Product/Produc...82E16814102305
I dont really wanna spend over 75 bucks, things are tight right now, so my question is, are any of those cards a decent upgrade or is the performance pretty much on par with what I have.
Please post some suggestions or links to other products you recommend.
Think the links are bad. I don't think there is anything worth getting or even better at that price. You should be looking to spend 150+ for a worthy upgrade.
That would be something like a 6600gt or 6800 non gt/ultra/
