Need advice on proper cable for HD install
jimmyjohn
I just purchased a Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM from newegg.
It is OEM and I didn't realize it would not come with the proper cables to conect it to my MotherBoard. I recently replaced my Power Suppy so I do have the new cable for the SATA Power.
My problem is I do not know what SATA data cable I need. And do I need a Serial ATA Controller?
If I do then will the data cable go from the HD to the controller or will the SATA cable go direct from the HD to the MotherBoard (Abit IS7) ?
If I just buy any Sata data Cable will it be the right one?
I should have just bought retail so I would get the cables included but too late now I have OEM and need the right cable....Please help ..........
Your MB has SATA ports onboard, if you have the proper SATA power cable, all you need is the SATA Data cable to plug in the MB, and set up in BIOS for use. (May already be enable by default, I do not know for sure...)
No new controller required, the onboard is technically slower than the HDD is capable of, but you probably couldn't tell the difference anyway..
Link to a cable below...
http://www.newegg.com/Product/Product.asp?Item=N82E16812104693
