Upgrading my PC after a long time using the old one. Current system is an AMD Athlon 2800+/Asus A7N8X-E/GeForce FX 5900 XT with 1 GB RAM. Screen is a 19 inch Viewsonic G90+ CRT. Max res of 1920 x 1440. Only running XP Home too.
Majority of the time I just use the net, a bit of photoshop, a small bit of video processing (to ipod format) and slight slight gaming (WoW, Warcraft 3, strategy games, old NBA Lives).
I mainly want it to run well for general tasks and if I did want to play the odd new game, at least run on reasonable settings. Nothing special as I probably won't be playing any PC games bar a few older ones.
Don't need crossfire, firewire, don't know what RAID or SLI is so guess I don't need that.I'm in Australia so don't worry about prices as I'll look them up here. Need info on the parts.
I want this to last me at least 5 years too. Just an idea but might be too powerful or not powerful enough.
CPU - Intel E8400 (Would a lesser like E5200 or E7300 be enough? Or even a higher end AMD??)
MB - Was thinking Asus P5Q-SE or the GB EP45-DS3-L but don't know a lot about MB and their features so maybe that is overkill?
RAM - 3 GB maybe as using XP Home. 1 x 2 GB stick and 1 x 1 GB stick
HDD - Don't mind brand but at least 500 GB and up to 750. I think 1 TB is too expensive still here.
GPU - Undecided here. Either a 9600GT, 9800GT, 9800GTX or a HD 4850. Highest I will go is the 4850. Knowing my gaming needs, I need advice here on what is overkill.
CASE & PSU - Depending on what is above, either the Coolmaster CAC-T05 which comes with a 460W or the Antec NSK6580 (not sure of what PSU it comes with but it's at least 400W I think).
OPTICAL - Pioneer 215/216BK is an easy choice here for a burner.
TOTAL - In Australian, a variation of the above can range anywhere from $500 AUD to $1,000 AUD. I won't spend over $1,000.
My main concern is over or under kill ( a word?). Knowing my needs, I don't want to get parts I don't need but on the other hand, I don't want to have to upgrade in 2 years because something isn't compatible anymore. I need a balance.
Any tips are greatly appreciated.
Thanks
Thanks
