Need Advice On New PSU
slamcmy
hi guys right now im running my q6600 g0 stepping at 3.0 ghz and i have an antec 500 watts power supply and getting ready to change my video card and i may need to change the power supply, my question is: once i change my power supply will i have to change my cpu voltages again to get a stable overclock, my system is 100% stable on prime95 small ftt's torture test for 32 hrs thats how i tested my overclock and i dont wanna go trough that again :) or everything remains the same in the bios and i wont need to change anything in there, just switch power supply get the connections right and i should be ready to go ?
thanks for your time
I have to get a new PS to go SLI so I'll let you know in about 2 months.
But I think you should be fine, and it's fun to re overclock.
No, you shouldn't need to change any settings granted your previous and current PSU rails are stable and within spec.
