I recently came into a ton of free hardware, which I will list out to get started so you know what we're working with.
Server:
HP ProLiant DL385
Single 2.8GHZ Opteron
4GB of RAM
2x 74GB 10k SCSI Disks for the OS (Mirrored)
Windows Server 2003 64-bit R2
Add-in Controller Cards:
Silicon Image SiI 3124 SATALink Controller (4x eSATA ports)
Silicon Image SiI 3124 SoftRaid 5 Controller (4x eSATA ports)
Smart Array 6i
Disk Enclosures:
2x Norco-4104 12-bay SATA disk enclosures
One has 12x 500GB SATA disks
The other has 8x 500GB SATA and 4x 1TB disks
What do I want to do with this?
All I want to use it for is torrenting and LAN video streaming (planning on using Tversity for that)
I'm making this post because I'm not sure what the best way to configure these volumes/cards, or if I even have the right cards that I'd ideally want. Now I'll give you some more detailed information about what I'm currently seeing.
Right now the server is hooked up to only one enclosure, through the SoftRaid5 Controller. I need 4 more eSATA cables to hook the other one up, so those are on the way.
When I go into disk management, this is what I see:
Note: The 273GB disk is something I intentionally brought offline, in order to save a little power
When I go into the properties of the SoftRAID 5 card, it detects all 12 disks:
I've been into the RAID config on the Silicon Image card, and it really doesn't have many options - as well as shows some weirdness. It only ever shows 4 disks, so I ended up configuring it with no RAID in the Silicon Image BIOS. However, when I booted up as you can see, it shows 2x 1.5TB volumes as well as a single TB volume, is that how it's supposed to be? Also, I've ran hardware diagnostics on every single drive and weeded out the ones with issues, so that can be totally taken out of the equation.
Ideally the way I want it to work would be 2 volumes in Windows, one for each enclosure, and to be using RAID 5 for redundancy. I don't plan on backing this up, so I'm going to rely on RAID to be my backup (yes I know, RAID isn't a backup - but it's better than nothing?)
Oh and, this wouldn't be complete without a few pics..
Server:
HP ProLiant DL385
4GB of RAM
Smart Array 6i
Disk Enclosures:
