I wasn't sure whether or not this should go in cases or water cooling, but since I'm going to have to modify my case one way or another, I figure this is the best place.
I bought a Corsair 100R Silent Edition for my new build. I've had limited time to work on it, but basically I've had it all assembled except the side panels for a week now. I've been running stress tests before I clean up the cables and put on the sides. I have an Arctic Liquid Freezer 120 for cooling. Corsair's page for the case has a picture that shows it with what looks like an H80 in it, which has the same dimensions as the Arctic cooler, and looks pretty much just like my setup.
This past weekend it had passed the tests and I was ready to finish it up. When I tried putting on the "front" side panel, it wasn't catching at the top in the back. I then discovered that it was because there is a lip on the panel that can't go on due to the radiator being in the way. I can push hard and force it in, but it bulges out.
This is what the side panel looks like. You can see the lip that runs at the top, bottom and front of the case. Here is a closer look, which you can see at the bottom left corner is a flattened area so that it clears the mount post for the 5.25" drive bays. That mount post sticks out about as much as the radiator.
Other than getting a new case, I can only see two options:
1) Try to flatten the lip so that it will clear the radiator.
2) Move the radiator to the front, but in order for it to fit in that front fan spot, the radiator will have to be turned on its side, which from what I've read shouldn't matter as far as cooling goes.
For option 1, I could bang it down with a hammer, but I'm worried about damaging the panel. If I go that route, I think I'll use my dremel and try to grind it down instead.
Option 2 requires a little modification too. If you look close at the front fan mounts, they are threaded and use long screws to attach the fan. The holes and screws are a smaller diameter than what are on the radiator, so in order to mount the radiator there I will need to drill out the holes. I can mount one of the fans on the other side of that wall behind the front panel (there is already one in front of the HD bay), so the only space it will take up in the case is the width of the radiator and one fan.
Option 2 sounds like the easiest because drilling out 4 holes should be easier than grinding down that lip. The only down side to that is that it moves the noisiest part of the system up front.
I can't make up my mind. Just when I think I've decided and go to do one or the other, I stop and think then change my mind. I'm reaching out to see if anyone else can think of something I haven't, or offer a suggestion that will me make a final decision.
