Need Advice on Mobo/RAM
marka87uk
OK, I've just ordered Opteron 144, Freezer 64 Pro, and Sapphire X800 GTO2.
I suppose you are already guessing that I'm planning to unlock and overclock! ;)
Basically I need advice on which motherboard and memory to buy. I was thinking of the Asus SLi Deluxe and 2 x 1GB of Crucial Value RAM (http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=117457).
Will everything be compatible? Would you suggest anything else?
