D
Deleted member 218490
Guest
I'm looking to build some kind of data redundancy setup for my media content / HTPC and I've been considering a couple of options.
1. Buy a 4 bay or 8 bay RAID enclosure, attach it to my main PC and stream it to my HTPC, or vice versa.
.......... * If I buy a 4 bay I would use 2TB drives. I'm extremely concerned about
.......... the reliability of these high volume drives. Is my concern legitimate or is
.......... there simply a lot of unwarranted fear online regarding their reliability.
.......... * If I buy an 8 bay I would use 1TB drives. Less storage space and probably
.......... more expensive as well.
I am not considering a NAS in this instance because their cost is so damn high
2. Build a storage server with a RAID controller card and configure it to either 4 or 8 drives like mentioned above.
3. Buy (4) 2TB drives and install 2 in my main PC where I put most of my media, and then have (2) 2TB in a separate enclosure. Clone the data on a weekly/monthly basis and keep it disconnected from the PC so that the data is safe. This would be the most tedious but probably the most safe
4. ???? Other ideas.
I don't have much experience with any of this, so any input/advice would be appreciated.
My budget is limited, and I'd like to keep the cost under $600 for everything. Unfortunately I don't know how realistic that is so I may have to piece the system together.
