OK, I"m building a mobo for a friend of mine, I need an AMD mobo that supports Athlon XP and has onboard sound + lan, sound especially.... I also need the motherboard to support overclocking. This is a budget PC so if you wanna recommend a cheap Athlon XP that would overclock very well with the retail cooler on it that would be great too......... Thanks guys, I can always depend on you
