archivalbackup
- Oct 12, 2007
I know there are a lot of Cisco minded people lurking in the Forum, so I wanted to look for some been-there done-that experience.
I need to come up with a parts list for a wireless backup between two sites in case the primary 1Gb fiber link is cut.
History - there are currently two fiber pulls, but one is in the ground and keeps getting cut with backhoes (no location wire) and is currently cut (again). Currently load-balanced in an ether channel.
The two buildings are .5 Miles, direct line of site (may need mounting bracket to a pole).
Sustained transfer is 1800Kb with reasonable duration peaks from 3600Kb to 4600Kb. Applications are Database driven, latency sensitive, and very mission critical.
Upgrade path to N would be a plus, however dependability is a must. I am looking for suggestions on a Cisco point-to-point bridge that needs to stand up to heavy rain, fog, snow etc. Overkill such as high gain directional antennas is better than being cheap to make sure the backup link works when needed.
I also need to do some thinking on how I want to setup the fail over. Currently there is a fairly dumb HP switch at one of the sites, and a good Cisco at the other, so failover was setup with ether channel since the medium & speed were the same. Perhaps UDLD aggressive and tinker with the spanning tree (only the core of the network is routed at the moment). Worst case someone can always type in a command but this is not ideal.
So I need help coming up with a parts list, and experience/potential shortfalls for a wireless backup link.
