Need advice on a case
Chris__
I'm wondering if this case I found on the web is any good. I haven't found many helpful reviews on the web so I figured I would ask here.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2337810&CatId=1842
My main concern is noise, I really need/want a quiet computer. The case I have now is just really loud for some reason even though I have quiet fans (Zalman, Vantec "Stealth"... which I assumed meant little noise). I've already got a power supply so thats not a consideration.
Anyways, has anyone used that case before? Can anyone recommend a case from that site? Preferably under $100 (Canadian, no newegg :( ) and without a PSU.
Thanks in advance.
Any case can be quiet. Depends on which fans you buy. Do some looking around for silent pc threads.
