Need advice mounting to concrete
samssf
Hi all,
I bought an ergotron LCD wall mount (I owned their LX desk mount for my previous setup and it was awesome). I live in a highrise condo building and should have figured the walls would be concrete. However, it also seems there's at least 1" of drywall over concrete (maybe two layers?). I got a couple 3-1/8" lag bolts and 2" plastic lag shield anchors with the package.
Their illustration in the manual shows the drywall being a maximum of 5/8" thickness and the rest of the bolts/anchors being in concrete, which is confusing to me since the drywall could be up to 1-5/8" and all of the anchors would still be in concrete.
Also, this seems like a massive amount to drill into my wall... does anyone know what the average wall thickness would be for a new condo building?
Also, is there any way to get the plastic lag shield anchors out once I take down the setup and move out? (I'm renting).
Thanks
How heavy is the monitor and how far from the wall does the mount let you position it?
We need some idea of the moment on the mount to advise you.
The maximum distance from the wall is about 2', but I will have it at about 1' away. The weight of the monitor is probably < 15lbs, and the mount itself around the same.
I'm considering ditching the lag bolts and shields they sent me, and drilling 3/16" holes following by some 1/4" 2-3/4" tapcon screws with hex head. That way I could simply unscrew them from the drywall and patch without leaving behind the lag shield. Thoughts?
I'd be careful, If you get the tapcons to bite the concrete good it should hold. Myself I'd be tempted to go for an actual split bolt/expansion bolt type anchor if I was going to hang my new monitor off it.
What is the management going to say about you rotohammering holes in their condo?
Rotohammer? I'm not planning on using a hammer drill - was hoping a standard drill with a carbide bit would be enough to get through 1-3/4" of concrete.
The holes will only be 3/16 to 1/4 in diameter, so I was planning on just patching them when I move out, like I would any other hole. Do people not mount things on their wall when renting?
*Edit* So looks like I will probably need a hammer drill, but I talked to management and it doesn't seem like it'll be a problem. However I will probably go with tapcon screws which should make it a bit easier.
Ok, so, I'm back to square one.
Management doesn't care about me drilling holes in the wall as long as they're not too big (1/4" is fine). However, no one around knows for sure what the walls between units are made of. Each time I talk to a technician here, they say "watch out for water pipes (we have hydronic wall heating)" or say "yeah no problem the walls are hallow and are sheetrock over wood studs".
So basically they don't know, and I don't want to drill into the wall if I don't know what it's made of. So I'm hoping someone can help with that.
The wall I'm going into is between me and another unit, and it definitely has around 1" of sheetrock (two layers) over some other material. Also, I have used two studfinders on the whole wall, and they go off around every 14 - 16", and they go off in the same position vertically along the wall.
If the wall was sheetrock over concrete, would there be studs every 16"?
Also, I hit something metal when drilling into the wall (about 1-1/4 to 1-1/2 in). Before I hit metal I could have swore I was drilling into concrete, so I'm wondering if I hit rebar.
Does anyone know about how modern highrise buildings are constructed, or can send some resources by way? I searched google with multiple queries but I can't find anything about this subject.
Thanks again.
*Edit* I put a finish nail into the drywall a few inches from my original hole and after going through about 1 to 1-1/2 of drywall, went through and the wall is hallow. This is surprising to me since for sound isolation I would expect the wall to be concrete. So now I have to determine if I should mount the LCD to the metal studs or just to the drywall. I'm thinking that two 1/4" toggle bolts should be able to support a couple hundred pounds when put through 1.5" of drywall. Thoughts?
