need advice, GPU for a small itx build
iakovl
right now i'm building my itx pc, main problem is not the length of the card but how much power can i provide to it
the rig will use FLEX psu (or i might go with SFX) so the power is going to be 250~300W max.
with that in mind the rest of the rig will be:
  • Intel I5 2500 (might get a low TDP version)
  • 1155 mobo
  • 2*4 GB DDR3 ram
  • 1 HDD
  • 1 SSD
i'm not a "gamer" but i do play from time to time, right now i have a 4850 with my current rig and it's ok...
need some recommendation on this mater
also
the card should be too long, it is an itx build, the mobo is only 17cm and while the gpu will be longer, i dont want to make it, too long
