I am getting ready to buy a watercooling system for the first time, I am sick and tired of air cooling and I have done a lot of research and have picked the following components for my system.
I am more than willing to take suggestions, I just want to get the best system possible for my situation. I would also like to know if the system I want to buy will be able to handle the heat load I am going to throw at it.
Ok to start it off.
The components I have in my current system.
DFI SLI-DR Expert
Opteron 170 DualCore @ 2.4 240x10 4xHTT 1.475v (Trying to CPU Burn in a higher OC)
Mushkin Redline XP-4000 1024MBx2 3-2-3-8 2.67v
2 XFX 7800GT @490/1150 in SLI.
Lian Li V2000 case
Now I do not want to do any cutting on my case in any way. I just got it and I love it and don't want to hack it up quite yet.
As you might or might not know the V2000 has 3 exhaust fans 1 x 120mm and 2x80mm in the Power Supply compartment, I want to use these for my rads.
The components I have picked out are:
(All 1/2" Fittings)
Swiftech Storm G4
DD A8N Chipset Block (I think this will fit on the new SLI-DR Expert)
Black Ice Extreme 1x120mm Rad
Black Ice Micro 2
MAZE4GPU-SLI
DD-D5 Pump
I am going to be using Tygon 1/2" ID 3/4"OD Tubing for the whole system.
Misc Odds and ends, such as coolant additives, hose clamps, etc.
My plan is to run a T-Line instead of a Res. I dont want to screw with em.
Now for plumbing I am planning on placing the pump probally a few inches twoards the front of the case from where the brace is (Its removed on mine).
The system flow Im planning on (Need suggestions, I only want to do 1 loop, cant afford 2 pumps)
-->Pump---->>CPU->>>GPU1--->GPU2--->Chipset--->120MM Rad--->Dual 80mm Rad---Pump..
The other option I have been thinking about is,
Pump---->CPU----> Dual 80mm Rad-->GPU1-->GPU2--->Chipset--->120MM Rad--->Pump.
How will this setup work, are the 2 rads going to be enough to cool the amount of heat I am putting out. I am probally going to use Meduim speed Panaflows, then adjust their speed based on the total system temps once I get it set up..
Just need some inputs, suggestions, advice.. etc.. Any help welcome.. Thanks!
Ok to start it off.
DFI SLI-DR Expert
Lian Li V2000 case
(All 1/2" Fittings)
Swiftech Storm G4
Black Ice Micro 2
MAZE4GPU-SLI
DD-D5 Pump
